When the need arises for linear motion
or positioning, there are many choices.
One can use an Acme screw, ball screw,
rack & pinion, or belts. The cost of a linear motor solution is generally greater than a mechanical linear product, but when one needs highly accurate, repeatable, high-speed motion, then the answer may be a linear motor.
Equipment downtime and reduced component
life are a few of the consequences — and
potential costs — of using the wrong seals on many types of industrial equipment including pump bearing frames, electric motors, fans, pillow blocks, gearboxes and more. However, if
correctly specified and installed, seals provide effective barriers that both retain lubricants as well as protect against water, corrosion, debris and other contaminants.
Eddy Swiben, branch manager at BDI
Canada, explains how to problem solve
on an automatic cutter for tissue rolls.
“This is a very major paper tissue manufacturer that sells paper tissue rolls all over America.” They roll paper tissue just like newsprint paper mills do. When the product is finally done and dried, they need to roll it on a light carton core 20-ft. long.
Bearings are an essential component
in the majority of mechanical
designs and equipment.
It is important to consider the
most effective materials when designing
industrial machinery, especially in
applications where water or other liquids
are present. Many materials will
be unable to overcome the challenges
associated with operating in a wet or
corrosive environment.
It's no secret that conveyor systems are the primary market for gearmotors, and so it shouldn't be much of a surprise that gearmotor manufacturers are looking for ways to cater to that market's needs. From Brother's new VFDs to Siemens' Simotics S-1FG1, a lot of the new solutions in the industry have their own unique quirks, but all fall into a few common veins.
Pack Expo takes place November 6-9 at McCormick Place in Chicago. With 2,100 exhibitors, it’s the world’s largest most comprehensive processing and
packaging trade show in 2016.
Ernest Head (Arnie), CBS and technical
sales representative at Motion Canada
helped save a lumber industry customer
time and money by adapting a bearing
solution for another client. Here’s how:
When trying to find a new bonding material dispense system, one manufacturer tested a series of pumps — all of which leaked due to the abrasiveness of the bonding material. The manufacturer also had been attempting to manage shot size
manually with their previous system, and was not able to keep dispense consistent. The company searched for
a system that could accurately dispense programmed shot sizes while also eliminating the leaking issues they
had experienced with previous pumps. Graco provided a Check-Mate pump with SmartWare software, and the manufacturer is now able to automatically dispense shots of bonding material as small as one ounce without leaks.
Increasing pressure on many fronts is compelling mine operators to thoroughly examine every phase of their operations. Fluctuating demand
that whipsaws mineral prices, government-imposed environmental regulations and rising operating costs related to maintenance downtime all pose serious challenges for the mining sector. Add pressure from customers and stakeholders for more sustainable operations as well as union demands for higher wages, and you have a scenario that requires mine operators to exercise every possible option to
achieve more efficient operations.
Rolling-element bearings are high-precision components that need to be stored and handled carefully to perform as designed. Proper storage and
handling of a bearing before, during
and after installation is important because once debris enters a bearing, it
reduces the life.
