Axially space-saving, economical, IP65-compliant, and designed for high radial and axial forces at the output: The new WPLHE combines all the advantages of the successful PLHE, the world's first combination of the economy and precision gearboxes, as a right-angle variant.
The WPLHE features both the gearing of a proven economy gearbox and a high-performance output bearing with preloaded tapered roller bearings, which are otherwise commonly used in precision gearboxes (such as the PLN and the PSN). This means that the new right-angle gearbox tolerates high radial and axial forces of up to 8,000 N at the output. For example, pulley drives with high radial loads can also be implemented in right-angle designs.
Compared to the coaxial PLHE the motor is rotated by 90° in this case, the WPLHE offers the ideal solution in confined spaces, for example in packaging and other special machines. It is the only economy right-angle gearbox to be offered with a premounted pinion as an option. This makes it particularly suitable for space- and cost-sensitive rack-and-pinion drives. There are 13 different pinions from which to choose: with a choice of straight-cut or helical-cut teeth, from module 2 to 3, with numbers of teeth from 15 to 27.
Thanks to the output geometry with square output flange and long centering flange that has become established on the market, the WPLHE is easy to implement. Several different output shaft variants - smooth, keyed, splined, or with premounted pinion—mean that the right-angle gearbox can be used in a wide range of applications. It is also the only economy right-angle gearbox with IP65 protection class, making it suitable for harsh, dusty, and dirty environments. Food-grade and low-temperature lubricants are also available for the lifetime lubrication commonly provided by Neugart.
The new WPLHE is now available in three sizes 060 / 080 / 120, either as a single-stage version (in the ratio range of 3 to 10) or as a two-stage version (ratios 9 to 100). Thanks to an efficient supply chain, Neugart can continue to guarantee attractive delivery times for quantities starting at one.
Neugart is extending its portfolio of planetary gearboxes, especially for rack-and-pinion drives, with an additional option for a mounted pinion from its in-house production.
Two specific types of pinion are available: the PK1 pinion is mounted to the splined output shaft of the gearbox, whereby the secure connection that is required is provided by internal teeth in accordance with DIN 5480. The PM1 pinion, on the other hand, is designed for gearboxes with a flange output shaft, and is equipped with a mechanical interface which is standardized in accordance with EN ISO 9409-1. Both types are available with a helical cut, and the PK1 is also available with a straight cut. The pinions are also available in four different modules and with different numbers of teeth.
The pinion option can also be combined with a total of eight gearbox series: including a coaxial planetary gearbox with an output shaft (PLHE) and an output flange (PFHE) from the Economy Line, which include durable and powerful standard gearboxes with an outstanding price/performance ratio. Two coaxial planetary gearboxes with an output shaft (PSN and PLN) or output flange (PSFN and PLFN) and right-angle planetary gearboxes (WPLN and WPSFN) are available in the Precision Line, which represents the outstanding accuracy of precision gearboxes.
These numerous pinion/planetary gearbox type combination options ensure that not only can a solution be found for a wide range of applications, but usually several, meaning that the torsional stiffness of the flanged gearboxes is greater than that of gearboxes with an output shaft. If the construction space situation is the decisive criterion, the constructor can use the short gearbox with the output flange or the right-angle precision gearboxes. If precision is the decisive factor, the constructor can opt for the greater accuracy and torsional stiffness of the precision gearboxes. On the other hand, economy gearboxes are a solution that is financially more attractive for standard applications.
Complex load trends in the drivetrain can be calculated in the NCP, and the optimum application-specific motor/gearbox combination is determined on this basis. With the update, it is now also possible for propulsion drives in Automated Guided Vehicles (AGVs) and the new NGV gearbox range that is tailored to these vehicles. Existing projects from current or older NCP versions can now also be loaded for newly designed controlled systems and compared with them.
As well as these new functions, Neugart has simplified the operation of the tool with version 4.2 and improved user-friendliness: conversions are no longer required when importing read-out motor data, for example. Users of popular CAD programs can now also use the familiar full stop as a separator as well as the comma. Calculations can also be carried out in the input fields. And the gearbox documentation has also been optimized, meaning that the user detects whether the selected gearbox is suitable on the basis of utilization bars.
And finally, NCP 4.2 has an example for every application, which makes it easy to learn how to use the tool.
neugartusa.com
Hiwin—#134514
Torque Motor Rotary Tables (TMRT) are ideally suited to high-accuracy machine tool manufacturing where multiple axis operations must take place simultaneously. Hiwin offers several styles including RAB Series, widely used in 3+2 axis, 4+1 axis positioning processing, or 5-axis simultaneous processing.
Datorker strain wave gearing systems allow higher gear reduction ratios than other types in a more compact space. Widely used in robots, automation equipment, semiconductor equipment, machine tools, and other industries, Hiwin has developed various specifications and reduction ratios to provide customers with a wide range of choices. Hiwin can provide customized services to meet customers' various designs and requirements.
hiwin.us
Hexagon—#135202
Hexagon’s Manufacturing Intelligence division will feature its recently released 6D laser tracking system—the Leica Absolute Tracker AT500—in Booth 135202 in the Quality Assurance Pavilion. The AT500 platform delivers improved performance to both reflector and probing measurement, as well as plug-and-play setup times. Its new, customer-centric design includes several significant features including a battery-powered, integrated controller, full IP54-rated environmental protection, minimized cabling, and an expanded operating temperature range. Users no longer need to level the tracker or initialize a reflector before measurement begins. These enhancements and more translate to the most portable and robust laser tracker in Hexagon’s metrology portfolio.
Overall, the AT500 is built to provide exceptional user productivity and reduced time-to-results workflow. The laser tracker’s expanded operating temperature range of -15°C to 50°C provides accurate results for challenging measurement environments from mountaintops to foundries. With a measurement volume up to 320 meters and IP54-rated ingress protection, the AT500 stands alone in its field as the go-to technology for large-scale inspection applications on the factory floor, a tarmac, a solar farm, or a shipyard.
hexagonmi.com
