Rollon Puts an Emphasis on Design
The more things change the more they stay the same. This can also be applied to rolling guides.
“Over the last 15 years the evolution of the high precision linear guides has not really changed,” said Scott Spangler, distribution manager at Rollon Corporation. “The load capacity has been maximized due to ball conformity, cleaner steel, and envelope size. Sealing has been optimized and aside from adding additional seal accessories, we have just about maximized the amount of debris that can enter the bearing. Relubrication has been optimized to the point where the bearing will fail of other means before running out of lube. All of these factors theoretically increase the life of the bearing, but unfortunately most bearings don’t fail because of fatigue, they fail because of misalignment. Until Lean Engineers push the fact that a high precision bearing in a medium precision application will cost the customer tons of money downhill, the compliant linear bearing will not be the “new technology” linear guide.”
The cost of effective use of linear guides starts in the design stage. As Lean Design takes on a larger role within the entire design cycle it becomes imperative that engineers design a cost effective machine to the requirements of their customer.
Rollon provides customers with a compliant linear guide (the Compact Rail), in the range of 10x more compliant than the standard profile rail guide. This compliancy allows the machine builder to reduce cost in machining, assembly time and overall machine design. The feature of the guide allows for misalignment of 4 mm along the linear axis while retaining a stiff and accurate running system.
“The rotary bearings within the carriage are lubed for life. The rolling elements are much larger than the balls in a profile rail guide. So they are much less sensitive to any debris that finds its way to the raceways,” Spangler added.
When dealing with automation type applications, the load is typically light (<200 pounds) and accuracies above 200 microns. “There is no reason to use a high accuracy profile rail guide that handles 5,000 pounds and ground to microns of accuracy. If you do, you now need to mount the rails within 25–50 microns of each other. This requires machining of the mounting surfaces, shimming during assembly, and a very rigid mounting structure. All of this costs the machine builder thousands of dollars and is totally unnecessary. The cost of effective use of linear guides starts in the design stage. As Lean Design takes on a larger role within the entire design cycle it becomes imperative that engineers design a cost effective machine to the requirements of their customer. To keep machine costs low, maintenance at minimum and field failures out of the picture, the market must turn away from the profile rail guide and look at more compliant linear guides such as the Compact Rail,” Spangler said.
Rollon’s guides have been utilized in a variety of areas including machine tools (part loaders, tool changers, machine doors), logistics (automated warehousing, transfer systems, automated storage and retrieval systems), factory automation (packaging, assembly, sorting, pick and place, palletizing) and medical applications (scanning equipment, specimen testing, hazardous handing).
In the future, due to new materials and coatings, Spangler says that these rolling guides will find themselves in more food handling and washdown applications.
THK Invests in Future Linear Motion Growth
THK is taking major steps to meet the growing worldwide demand for linear motion products. In fact, THK has recently invested over a half-billion dollars in new brick and mortar facilities that will increase floor space for their global manufacturing operations to just under 10.5 million square feet. In the United States alone, THK has increased the number of components shipped by 30% over the last two years, with strategic production increases made to date as they focus worldwide to keep up with a demand for linear motion products that reached a 10-year high in 2017.
Orders for linear motion guides, components that enable machine tools to perform precise positioning operations in industries that include aerospace, machine tool, packaging and medical, increased by 31.6 percent in 2017. This figure far surpassed the industry forecast of 8 percent and late in the year supplies began to tighten as demand for these vital manufacturing components exceeded production capacity. THK, the company that first commercialized linear motion technology in 1972, took a strategic look at how to work expeditiously to fill existing orders and to positively address the long-term need to expand manufacturing to satisfy customer orders.
Committed to investing in the future, THK is expanding production with a capital investment of over a half-billion dollars at manufacturing facilities in Yamagata, Japan, and in Vietnam and adding a 366,000 square foot facility in India. This will increase THK production by an additional 30 percent once all expansions are fully in place. To enable increased production while maintaining a high standard of precision and accuracy associated with their products, THK is also automating processes at existing facilities, including at their U.S. manufacturing plant in Ohio. To assist in meeting customer demand for linear motion products, THK has further invested in research and development of its industry-leading LM components as well as in human resources. The company has grown from around 9,000 employees in 2014 to over 13,000 in 2017.
According to Stratistics MRC, the Global Linear Motion Systems Market is expected to grow significantly through 2026. Factors for this growth include rising revenue from replacement activities, a high demand for linear motion systems in the automotive industry and the rapid industrialization in emerging countries. However, lack of effective product differentiation is one of the major factors hampering the market growth.
Linear motion systems consist of linear rail, rail tables, guides, and actuators, sliders, which help the manufacturing facility to continuously transfer products in a conveyor belt, or push it across for packaging. By application, linear motion systems find significance across different applications in material handling such as palletizing, packaging, pick and place, sorting, and the transportation of goods. The deployment of linear motion systems in this application delivers agility and seamless processing, thereby reducing maintenance requirements.
By geography, Asia Pacific is expected to grow at a significant rate due to rise in industrialization in the emerging countries like China, India, Taiwan and South Korea. Further, the demand for linear motion systems is supported by the development in automation solutions and robotics in this region. These emerging technologies will determine how successful rolling guide applications will be in the future.
IKO International
Phone: (630) 766-6464
www.ikont.com
Rollon Corporation (A Timken Company)
Phone: (973) 300-5492
www.rollon.com
THK America, Inc.
Phone: (847) 310-1111
www.thk.com
