Machine and equipment manufacturers
today are feeling more pressure
than ever to reduce costs without sacrificing
machine performance — a balancing
act difficult to achieve. OEMs
often overlook a simple solution that
can have a positive, long-term impact
on profitability for themselves and
their customers, i.e. — the
elimination of bearing
lubricant. By eliminating
lubrication systems
where possible, OEMs
can reduce production
costs while at the same
time make their equipment
more marketable
and less expensive to operate
for end users.
What are the issues
with bearing lubricant?
According to a major ball
bearing company, 54 percent
of bearing failures
are lubrication-related
(Fig. 1).
Figure 1 Types of lubricated-related bearing failures (Source: SKF,
USA Inc.).
In a study by the
Massachusetts Institute
of Technology (MIT) it was estimated
approximately $240 billion is lost annually
(across U.S. industries)
due to downtime and
repairs to manufacturing
equipment damaged by
poor lubrication (http://
www.azom.com/news.
asp?newsID=11342). Improper
bearing lubrication
or re-lubrication accounts
for up to 40 to 50 percent of
machine failures. By eliminating
lubrication from
machinery, OEMs can minimize
the costs and risks associated
with maintenance
for the end user. At the same
time, costs related to the
proper disposal of oil can be
eliminated and the initial
expenditure for ancillary components
and processes (grease lines, zerks,
manifolds, etc.) can be decreased.
There is a lower-cost, easier-tomaintain
machine component that
eliminates the total cost of bearing lubricants,
i.e. — high-performance, dryrunning
plastic bearings.
Proper lubrication delivery is critical
for the operation of ball bearings, and
most require continued maintenance
for re-lubrication. The re-lubrication
process typically requires scheduled
machine downtime, which increases
maintenance costs and causes a loss of
production time. In addition, re-lubrication
maintenance practices often fall
short. While some processes are automated,
the majority of re-lubrication
is performed manually using a grease
gun. This seemingly simple task actually
involves a number of critical steps
to ensure proper lubrication delivery,
including correct amount of lube, the
right grease gun, proper cleaning, and
careful storage and handling conditions,
just to name a few. In addition,
it is critical to use the same grease for the entire lifespan of a bearing.
The technical training division of Life
Cycle Engineering conducted a study
that found 80 percent of maintenance
workers surveyed scored less than 50
percent when it came to the basic technical
skills needed to perform their job
“Bearing lubrication” was noted first
on their list of tasks (http://www.lce.
com/pdf/trainingneeds.pdf).
Figure 2 Proper lubrication is critical for the operation of ball
bearings.
Ancillary components for OEMs.
Using lubricated bearings can increase
manufacturing complexity and
expenses. They often need to be fitted
with grease zerks (fittings) and manifolds,
oil lines, and sometimes oil reservoirs
and pumps. Not only are there
extra costs associated with purchasing
these components, there are also manufacturing
costs associated with the
machining and assembly of the mating
parts.
There are also additional parts required
to protect them from contaminants.
According to the McNally Institute,
the leading cause of bearing
failure is due to contamination of the
lubrication by moisture and solid particles.
If as little as 0.002 percent water
pollutes the lubrication system,
it increases the probability of failure
by 48 percent; just six percent water
can reduce the lifetime by 83 percent
(http://www.mcnallyinstitute.com/02-
html/2-10.html).
Ball bearings require seals to keep
oil in and unwanted water and liquids
out, as well as wipers / scrapers to keep
dust and debris out as well. Seals only
last so long, and do not perform well
in dirty and dusty environments, and
can also increase friction in the application.
In agricultural machinery and
lawn mowers, where dust and debris
are prevalent during operation, seals
and wipers may require frequent replacement.
Other Costs Not Required for
Self-Lubricating Bearings
Labor. A major oil company studied
the time required to manually lubricate
a single grease point. The results
showed manual lubrication takes an
average of three-minutes-per-point.
The average machine has 20 grease
points to maintain. This correlates to
a total labor cost of $7,300 annually for
maintaining 20 grease points on one
machine, every day, seven days per
week (http://www.lubricationautomation.
com/ez.php?Page=2087). Another
source claims that the average plant
employs 2,196 bearings and spends
$60,000 in re-lubrication costs per
year; of that $60,000, $57,000 is used
for labor alone.
Downtime. Improper bearing lubrication
or re- lubrication accounts for
up to 40 to 50 percent of machine failures.
When a bearing fails prematurely, a number of actions may need to be
taken. Replacement of the bearings,
shafting, and even motors and other
parts can be very costly. If the machine
needs to be taken off-line, expenses
can potentially skyrocket. In a six-sigma
lean manufacturing guide (http://
www.plant-maintenance.com/articles/
lean_maintenance_for_lean_manufacturing.
pdf), it is estimated that the
average cost for downtime is $500 per
hour, and in some automotive and other
high-volume production factories,
downtime costs are considerably higher.
In addition, unplanned downtime
can cause a ripple effect that impacts a
plant’s production schedule.
Disposal costs. According to Valin
(http://www.valin.com/index.php/
blog/15-filtration/117-cut-lubricantcosts-
up-to-50), proper disposal of
lubricants by a process management company can amount to approximately
20 percent of the cost of annual lubricant
expenditures. This means if a
plant spends $50,000 per year on lubricants,
they will spend approximately
$10,000 in disposal costs. In addition,
the cost of the lubrication itself can impact
overall expenditures, as it is normally
petroleum-based and directly
linked to the price of oil.
Figure 4 Self-lubricating plastic bearings from igus are made from
high-performance polymers, which are corrosion-resistant and
maintenance-free.
Self-Lubricating Plastic
Bearings
Self-lubricating plastic bearings are
made of high- performance polymers
and, unlike rolling-element bearings,
slide instead of roll. They consist of a
base polymer that is optimized with
fiber reinforcement and solid lubricants.
The fiber reinforcements increase
load carrying capabilities and
wear-resistance, and the solid lubricants
are transferred from the bearing
to the microfinish of the shaft in order
to reduce friction. No external oil or
grease is needed for their operation;
self-lubricating bearings operate completely
dry. They are an ideal solution
for applications in labs and food-processing
machinery that require clean,
oil-free operation. Plastic bearings also
perform well in dirty environments
since there is no oil to attract dust and
dirt, like the agricultural industry. They
can be used on softer shafting, even
anodized aluminum, which has excellent
corrosion resistance and is usually
less expensive and easier to machine
than case-hardened material or stainless
steel.
Eliminate maintenance costs. Using
high-performance, self-lubricating
plastic bearings can significantly
reduce maintenance costs, as well as
reduce unplanned downtime due to
bearing failure. OEMs that use selflubricating
plastic bearings are able
to deliver a maintenance-free system
that increases their end-customer’s
production throughput and the overall
marketability of their product. In
the event that a self-lubricated bearing
does need replacement, the replacement
part (a small, inexpensive plastic
sleeve) can be purchased for a fraction
of the cost of an entire re-circulating
ball bearing.
Lower production costs. Plastic
bearings do not require the machining
and other processes required to install
ball bearings. They are less expensive
and do not require grease fittings,
lines or pumps. Plastic bearings also
can be used on less-expensive shafting,
such as aluminum or cold-rolledsteel.
Some companies offer online
calculators to predict bearing lifetime
to ensure it is ideal for the application;
this eliminates the need for testing and saves time and errors in material
choice.
Application parameters not conducive
for self-lubricating plastic
bearings:
High loads with high speeds; these
lead to excessive frictional heat buildup
and wear.
Highly cantilevered loads; since
self-lubricating plastic bearings slide
(unlike ball bearings that roll), linear
applications with higher coefficients
of friction may result in uneven movements
for highly cantilevered loads or
drive forces.
Extremely precise applications;
plastic bearings have a higher running
clearance than ball bearings — sometimes
.001" to .002" — and therefore
are not ideal for applications needing
extreme precision.
Extreme temperatures; plastic bearings
are not recommended for applications
with long-term temperatures
exceeding 484° Fahrenheit.
Field Application Examples
Using High-Performance
Plastic Bearings
Figure 5 Note: Based on ¾ inch closed linear bearing and assuming replacement is required once per year.
1. Agricultural. A manufacturer of
equipment specifically for the
farming industry produces ‘the Pick
Planter’ — which creates individual
planting row units using walking
gauge wheels to deliver a consistent
planting depth.
Oil-impregnated bronze bearings
with graphite plugs were used to facilitate
this movement — until they
began causing severe problems.
They were even requiring replacement
two to three times a season.
On the (U.S.) West Coast, the bronze
bearings were experiencing high
wear and premature failure due to
the very abrasive conditions caused
by high levels of volcanic ash in the
soil. On the (U.S.) East Coast, the
high salt content in the air caused
corrosion and seizure.
By replacing all 144 bronze bearings
with iglide self- lubricating
plastic bearings from igus, the pick
arms’ lifespan was increased by 500
to 600 percent. The actual bearings
cost 70 to 80 percent less than
bronze bearings and were more reliable.
2. Packaging. One manufacturer specializes
in vertical, form, fill and
seal (v/f/f/s) packaging equipment
for handling a wide range of products
— from green beans to candy
to detergent. The machines are capable
of reaching up to 160 cyclesper-
minute and withstanding loads
up to 15 pounds, while operating at
speeds of 750 feet-per-minute.
The manufacturer had been using
metal linear ball bearings. After
the metal bearings scored the shafts
and leaked grease on some of the
machines, the company decided to
replace them with self-lubricating
DryLin linear plain bearings. To
date, the linear bushings have surpassed
the 10-million cycle mark
on some of the company’s packaging
machines with little to no noticeable
wear.
3. Medical. In the quest to improve the
way prostate cancer is detected and
treated, a team of researchers from
the Worcester Polytechnic Institute (WPI) in Massachusetts have developed
a specialized magnetic resonance
imaging (MRI)-compatible
piezoelectric actuated robot.
To facilitate different types of motion,
the robot uses a DryLin linear
guide system and iglide plastic
self-lubricating plain bearings. The
linear guides facilitate translational
motion of the positioning module,
which provides gross positioning
for the robot’s needle driver. The
needle driver is a vital part of the
system, as it enables the rotation
and translational movement of the
needle cannula: a flexible tube inserted
into the patient’s body cavity
for MRI-guided diagnosis and
therapy.
The needle driver has a needle
guide sleeve, a collet locking mechanism
and passive optical tracking
fiducial frame. Two plastic plain
bearings are used in the front and
rear of the driver to constrain the
needle guide. The bearings enable
the robot’s motor to rotate the
needle using the collet mechanism
by way of a timing belt. This rotating
needle would reduce tissue
damage while enhance targeting
accuracy. Another 10 plain bearings
were used to create a revolute
joint, also known as a “pin joint” or
“hinge joint”, to provide single-axis
rotation.
The linear guides chosen are comprised
of hard- anodized aluminum
rails and carriages and high-performance
plastic sliding elements,
which do not interfere with the MRI
procedure. The linear slides operate
without messy lubrication, which is
important in a sterile medical environment.
They also feature a lowerprofile
for applications where installation
space is an issue.
The specific plastic plain bearings
used were an ideal choice for
the robot, as they are comprised of
FDA- compliant polymers specifically
designed for applications with
contact to food or drugs.
For more information:
PO Box 14349
East Providence, RI 02914
Phone: 1-888-803-1895
sales@igus.com; www.igus.com
