Design Feature Articles Bearing Lubrication Lubrication
What Lubrication Method Should I Use
in the performance and life of a rolling element bearing. Less than 10 percent of bearings reach their theoretical L10 life, and poor lubrication can be attributed to 80 percent of those that fall short. Ideally, a lubricant forms a film layer between moving components in a bearing, separating moving parts, minimizing friction and preventing wear between balls or rollers, raceways and retainers. Lubricants also protect metal surfaces from corrosion and moisture, dissipate heat and can even prevent the ingress of contaminants.
This article appeared in the April 2016 issue.
