DC motors possess linear relationships that allow for very predictable operation. For instance, if enough voltage is applied across the terminals of a DC motor, the output shaft will spin at a rate proportional to that applied voltage. You can take the ratio of the applied voltage over the rated voltage and multiply that number by the no load speed and get the running speed.
V-belts look like relatively benign and simple pieces of equipment. They're basically a glorified rubber band, right? Need a replacement? Just measure the top width and circumference, find another belt with the same dimensions, and slap it on the drive. There's only one problem: that approach is about as wrong as you can get.
Medical imaging equipment, water handling systems, conveyors, robotic systems and rotary and linear actuators are among the many devices that may be fitted with electric friction brakes to hold their loads in place when the power is off or disrupted.
One of our goals at Power Transmission Engineering is to help you understand, identify and select the best technology for your mechanical power transmission or motion control applications. With every project, you have to decide which components to use, and which suppliers, based on functionality, quality and price. We aim to help you make those decisions informed by providing the latest information on current technology, especially when it comes to mechanical components.
If there are two things
that are in tight supply in
the industry, it's time and
talent. Manufacturers are always
pressured to do more faster,
and the industry is producing
fewer experts to help them do it,
so the industry's had to get crafty
and find what time-cutting procedures
they can.
