» Motor Bases
Companies in Motor Bases
Industrial Automation Co.
Moventas Ltd.
MRO Electric and Supply
MROSupply
Pix Transmissions Limited
Potomac Electric
Stearns (A Regal Rexnord Brand)
Tampa Armature Works- TAW (Integrated Power Services)
TVT America, Inc.
