A division of Brother International Corporation, Brother Gearmotors offers a wide range of high-quality, sub-fractional AC gearmotors and reducers in demanding industries such as packaging, food & beverage, and unit handling. Brother Gearmotors is one of the world's largest fine-pitch gear manufacturers and was designed in response to the industry's demand for smaller, lighter more reliable and energy-efficient power transmission components.
Brother International Corporation, with its corporate headquarters located in Bridgewater, New Jersey, was established in 1954. Currently, Brother and its subsidiaries employ over 1,000 people in the Americas.
