Over the past 25+ years R+W has developed into a world leader in precision shaft couplings for torsional rigidity, vibration damping, and overload protection. Whether for micro motors or 10 megawatt drives, R+W couplings are customizable for most applications, while many standard models ship from stock. Configurable CAD models are available in a large number of file formats at www.rw-america.com
