Home >
Directory >
Gears >
Ring Gears-BevelRing Gears-Bevel
Get Listed for FREE!
Atlanta Gear Works
B & R Machine and Gear Corp.
Cattini North America Corp.Estabilished in 1954 and since 1962 entirely committed to the OEM business, Cattini is an Italian worldwide leader manufacturer of Gears for power transmission. Cattini has developed a wide manufacturing programme for gears covering almost the entire powertrain and driveline applications. Cattini is now proud to be serving the Americas through CATTINI NORTH AMERICA !
KHK USA IncKHK USA is a supplier of metric gearing designed for use in industrial automation applications. KHK USA offers over 26,000 configurations of spur gears, helical gears, internal ring gears, gear racks, straight & miter gears, straight, spiral, hypoid bevel gears, screw gears, worms & worm wheels, ratchets & pawls, gear couplings, involute splines & bushings, gear lubrications systems, and right-angle gearboxes. KHK’s products are produced in acetal, brass, bronze, cast iron, aluminum bronze, carbon steel, alloy steel, nylon, stainless steel, and fiber-filled nylon. Stock gear sizes range from Module 0.5 through Module 10 with diameters of 8mm through 600mm and lengths from 100mm through 2000mm. KHK USA stocks most of the gears in Mineola NY and offers a 3 Day Factory Direct program for all products. All product details including dimensional data, torque capacity, stock levels and current pricing, along with free 3D CAD models are all available on the KHK USA website.
Philadelphia Gear, Power Systems by Timken
Southern Gear & Machine
