Home > Directory > Gear Drives
Get Listed for FREE!
Aerospace Gearboxes Automatic Transmissions Automotive Axles Bevel Gear Drives Combination Drives Custom-Built Gearboxes Cycloidal Differentials Cycloidal Drives Differential Gear Drives Dual-Output Differentials Epicyclic Gear Drives Epicyclic-Planetary Differentials Gear-Shift Transmissions Gearbox Housings Gearboxes Gearboxes - Corrosion resistant Gearheads Gearmotors Harmonic Gearing Helical Gear Drives Helical-Bevel Gearboxes Helicopter Gearboxes Herringbone Gear Drives Hollow Shaft Gearboxes Hypoid Gear Drives Inline Gearboxes Manual Shift Transmissions Marine Gear Drives Miter Gear Drives Multispeed Gearboxes Non-lubricated Gear Drives Planetary Gear Drives Planetary Gearheads Planetary Phase Shifter Differentials Power Take-Offs Precision Spindles Rack and Pinion Drives Register Control Differentials Right Angle Drives-Clutching Right Angle Drives-Reversing Right Angle Gearboxes Robotics Gearboxes Servo Gearheads Servo Reducers-Cycloidal Servo Reducers-Spiral Bevel Servo Reducers-Worm Shaft Mounted Speed Reducers Speed Control Differentials Speed Increasers Speed Reducers Spiral Bevel Gear Drives Spur Gear Drives Tension Control Differentials Torque Control Differentials Traction Drives Transfer Cases Variable Speed Drives Winches Wind Turbine Gearboxes Worm Drives
AmTech OEM
AmTech, OEM supplier of precision machined gears, shafts, castings, forgings and other power transmission components.
Atlanta Gear Works
Atlanta Gear Works is a total-solution industrial gearbox design, engineer, manufacture and repair company headquartered in Dawsonville, Georgia. For more than 30 years, we have served the pulp-and-paper, power, plastics, steel and chemical industries with high-quality innovative solutions and 24/7 responsive service. We repair all brands of equipment and can reverse engineer all components to equal or better quality. In addition to our state-of-the-art facilities, we offer a complete range of field services including field machining, inspections, gearing and gearbox repair for gears ranging from the simplest to the most complex. We continually invest in our people, plant and processes with the sole goal of eliminating or minimizing customer downtime.
B & R Machine and Gear Corp.
Boneng Transmission USA LLC
Brother Gearmotors
A division of Brother International Corporation, Brother Gearmotors offers a wide range of high-quality, sub-fractional AC gearmotors and reducers in demanding industries such as packaging, food & beverage, and unit handling. Brother Gearmotors is one of the world's largest fine-pitch gear manufacturers and was designed in response to the industry's demand for smaller, lighter more reliable and energy-efficient power transmission components. Brother International Corporation, with its corporate headquarters located in Bridgewater, New Jersey, was established in 1954. Currently, Brother and its subsidiaries employ over 1,000 people in the Americas.
Cattini North America Corp.
CHUN YEH GEAR CO., LTD.
Gears are one of the most used mechanical parts and are extensively used in mechanical transmissions, commonly used in our daily life as well. No mechanical equipment can work without gears. In modern industry, they play an important role. Chun Yeh Gear Co., Ltd. is a Taiwan-based transmission gear manufacturer & supplier. We are experts with experience of 30 years that aim to provide clients with the highest quality products. Manufacturer of Transmission Gear Parts and Worm Gearbox.
DieQua Corp.
Gleason Plastic Gears
We are a total solution manufacturer of the most accurate and economical plastic gears on the market - guaranteed! There are only a handful of companies that manufacture plastic gears and specialize both in Plastic Gear Design and the production of Injection Molded Gears. Gleason Plastic Gears is on the top of the plastic gears manufacturer list for one simple reason, we have the technology others do not. Plastic Gear Design and Injection Molded Plastic Gears including: spur gears, parallel-axis helical gears, crossed-axis helical gears, internal gears, planetary gears, face gears, cycloidal gears, evoloid gears, segment gears, non-circular gears, and asymmetrical gears, all by Gleason Plastic Gears Gleason Plastic Gears has discovered how to injection mold plastic gears with no weld-lines without secondary machining. Ask other plastic gear manufacturers if they can do the same and you will probably get a multitude of complex answers.
JIE Drives
Lafert North America
Your best source for Metric Motors, Gearboxes and Coolant pumps, by providing quality products with the highest level of service in the industry.
Midwest Gear & Tool, Inc.
With more than 20 years in gear manufacturing, Midwest Gear & Tool has an elaborate straight and spiral bevel gear manufacturing capability. We also manufacture a complete line of hydraulic, electric and manual transmissions and reducers. We m...
Miki Pulley US
Miki Pulley offers design solutions for a wide range of motion control applications. Our global network of manufacturing facilities and sales/distribution offices ensure prompt and reliable technical assistance in the U.S. and around the world. Miki Pulley collaborates with design engineers to identify the most cost effective solutions for motion control and mechatronic applications.
NORD DRIVESYSTEMS
NORD DRIVESYSTEMS designs and manufactures gear units, electric motors, and variable frequency drives that are engineered for adaptability. Their innovative solutions power a wide range of applications in over 100 industries throughout the world.
Nordex, Inc.
Philadelphia Gear, Power Systems by Timken
Philadelphia Gear was founded over a century ago to provide state-of-the-art gearing for the emerging industries of Pennsylvania. From those modest beginnings in 1892, Philadelphia Gear has earned a globally recognized reputation for expertise in power transmission solutions for the world's Energy, Infrastructure and Defense industries. Our world-class engineering and technical staff provides our extensive customer base across the globe with a full-range of solutions including: Onsite Technical Services - OTSâ„ ; inspect, repair and upgrade capabilities, renewal parts and new enclosed drives.
Regal Rexnord
Regal Rexnord is a major producer of mechanical power transmission drives, components and bearings, serving a wide array of machinery-intense industries, including forestry and wood products, mining and quarrying, power generation, and heating and ventilation.
SEW-EURODRIVE
Southern Gear & Machine
Spiroid Gearing
Stock Drive Products/Sterling Instrument (SDP/SI)
Sumitomo Drive Technologies
Turner Uni-Drive
Turner Uni-Drive engineers, manufactures and repairs industrial gearboxes, speed-reducers and transmissions. Since 1932, Turner Uni-Drive has been providing solutions with thousands of ratios and torque capacities to industry. Along with a full line catalog of standard gearboxes with varying capacities and up to 9 different speeds of your choosing, Turner Uni-Drive designs and manufactures gearboxes for specific applications to meet and exceed our customers specifications.
U.S. Tsubaki
The Tsubaki brand has been globally recognized for its superior power transmission and motion control products. Since 1917, The Tsubakimoto Chain Company, headquartered in Japan, has been moving the needle forward by constantly innovating new products and expanding its global operations.
Zero-Max
Since 1949, Zero-Max, Inc. has created innovative solutions to motion control problems worldwide. With strategic distribution points located throughout the world, Zero-Max can deliver your motion control solution. The Zero-Max team of application specialists can engineer a solution to meet your motion control requirements.
ABB Motors
ABM DRIVES INC.
Abtex Corp.
Accent Bearings Co. Inc.
Accurate Gear and Machine, Inc.
Ace World Companies
Acme Gear Co.
Aero Gear Inc.
Agnee Transmissions (I) Pvt Ltd
Agro Engineers
AIMS Industrial Supplies
AKGears, LLC
Akron Gear and Engineering
Allied Motion
Amarillo Gear Company LLC
American Gear & Engineering
American Refining Group, Inc.
Ancon Gear & Instrument Corp.
Anuze Motor Smartech Co. Ltd.
Area Distributors Inc.
Arnold Magnetic Technologies
Artec Machine Systems
ASI Drives
Assun Motor Pte Ltd
Atlanta Drive Systems Inc.
ATO Gear Motors Inc
ATO Inc
Avers Machine and Gear dba Innovative Rack & Gear
Avion Technologies Inc.
B&B Manufacturing, Inc.
Baart Industrial Group
Bauer Gear Motor (A Regal Rexnord Brand)
Bearing Engineering Company
Bearing Service Company
Bevel Gears India Pvt. Ltd.
Bierens Machinefabrieken B.V.
Bison (Ametek)
Bodine Electric Company
Bonfiglioli Riduttori S.p.A.
Bonfiglioli USA, Inc.
Bosch Rexroth
Brad Foote Gear Works, Inc
Buehler Motor, Inc.
C-B Gear & Machine, Inc.
Cascade TEK
Central Gear & Machine
Chenta Gear USA
Cincinnati Gearing Systems
Cincinnati Steel Treating--CST
Cleveland Gear Co.
Cogmatic
Cold Forming Technology
Columbia Gear Corp.
Community PC
Comtec Mfg., Inc.
Cone Drive
Cotta Transmission Co. LLC
Currie Enterprises
Curtis Machine Co. Inc.
Dana Fairfield
David Brown Santasalo
Delroyd Worm Gear (A Regal Rexnord Brand)
Desch Canada Ltd.
Dorris Gear Drives
Drive Lines Technologies Ltd
Duff Norton Australia
Dunkermotoren USA Inc.
Dura-Bar
Electronic Machine Parts
Elliott Manufacturing
Ensinger Precision Components
Essential Power Transmission Pvt. Ltd.
Evolvent Design
Excel Gear, Inc.
Fairchild Industrial Products Co.
Filmecc USA
FMC Engineering
Focus Technology Corp.
Forgital Group
Framo Morat Inc.
FVA GmbH
GAM Enterprises
Gayatri Gear Industries
GearTec
GKN Automotive
Groschopp Inc.
Halifax Rack and Screw Cutting Co Limited
Hallmark Industries Inc.
Harmonic Drive LLC
Haumea Srl
Hero Motors
Hoffmann Technics AG
Houston Pump and Gear
HPB Motion Control Co. Ltd.
I-MAK Reduktor
IMO USA Corp.
Impro Industries USA, Inc.
IMS LLC
Industrial Automation Co.
Indwel Precision Gears Pvt Ltd
Integrated Components Inc.
Involute Powergear Pvt. Ltd.
jbj Techniques Limited
Juncera Automations
JVL Industri Elektronik A/S
K+S Services
Kachelmann Getriebe GmbH
KEB America, Inc.
Kisco Gears
Kollmorgen (A Regal Rexnord Brand)
Koro Industries, Inc.
Kraft Power Corporation
Leeson Electric (A Regal Rexnord Brand)
Lenze Americas
Li Gear
Logan Clutch Corp
Marshall Engineering Works
Maxon Precision Motors
Midwest Motion Products, Inc.
MIJNO-USA
Minsk Gear Works
Mitsubishi Electric Automation, Inc.
MMR Precision Gears
Molon Motor and Coil
Moventas Ltd.
Nabtesco Motion Control, Inc.
Neugart USA Corp
New Power Electric (USA) LLC
NGC Transmission Europe GmbH
Nidec-Shimpo Corporation
Niebuhr Gears
Ningbo Zhongda Leader Intelligent Transmission Co.
Nuttall Gear (A Regal Rexnord Brand)
Om Engineering Works
Ondrives US Corp.
Onvio LLC
Ormec (Allied Motion)
P. G. DRIVE
PEACO Support Inc
Phytron, Inc.
PIC Design
Pinpoint Laser Systems
Portescap (A Regal Rexnord Brand)
Power Electric
Power Engineering and Manufacturing
Precipart
Precision Arrow Gear Co.
Precision Microdrives Limited
PTG Holroyd
Pulsgetriebe GmbH & Co. KG
QTC Metric Gears
Quality Reducer Service
Radicon Drive Systems, Inc. (Elecon)
RAE DC Products Group
Redex USA Inc.
Renk Test Systems
Renold Ajax
Rex Engineering Corp.
RGW Sales Canada
Ricardo UK Ltd
Riley Gear Corporation
Ringball Corporation
Rj Link International, Inc.
Rolling Motion Industries
Sensata Technologies
Sesame Motor Corp.
Shreecon Gear
Siemens Industry, Inc.
Sinotech
SIPCO
Siti Spa Riduttori
Six Star
Snow Nabstedt Power Transmissions Inc
Source Engineering Inc.
Spencer Pettus
SPN Schwaben Praezision
ST Gear & Machine LLC
STM Riduttori SpA
Stober Drives, Inc.
Stoffel Polygon Systems, Inc.
Supreme Gear Co.
Tampa Armature Works- TAW (Integrated Power Services)
Team Industries
TelcoMotion
Thomson Industries Inc. (A Regal Rexnord Brand)
Tien Yi Gear Works Co.,Ltd
Toledo Gearmotor
Tolomatic, Inc.
Torque Transmission
Transcyko
Triumph Gear Systems
Trojon Gear Inc.
TVT America, Inc.
Var-Spe Variatori Oleodinamici
Varitron Engineering (Taiwan) Co., Ltd
Venture Mfg. Co.
VL Motion Systems Inc.
Voith Turbo Inc
WEG
WEG Cestari Redutores
Wittenstein
WMH Transmissions Ltd
WPT Power Corporation
Xtek, Inc.
Yilmaz Reduktor Sanayi ve Tic A.S.
York Industries
Zhengzhou AOKMAN Machinery Co. Ltd.
ZRIME
