AST Bearings is a leading supplier of precision ball and roller bearings, cost-efficient rotary assemblies, custom bearing solutions, and related value-added services.
NSK is a global manufacturer of bearings and other motion & control products. It operates 51 manufacturing facilities worldwide and 12 global technology centers of excellence that draw from world-leading industry knowledge and manufacturing experience. NSK's dedication to engineering innovation results in state-of-the-art products designed to improve performance and extend service life. NSK's unique Asset Improvement Program helps customers improve productivity and efficiency to significantly reduce operating costs. The company's industry and process-specific expertise and solutions are applied to identify and solve problems that are limiting productivity. This enables customers to achieve improved performance, enhanced competitiveness and increased profitability.
PBC Linear is a leader in the engineering, manufacturing, and assembly of a wide range of linear motion products, along with custom engineering services. Our core line of linear components includes bearings, shafting, rail assemblies, and cam roller sliders. Building on this strong foundation, we have created a sophisticated family of products that includes lead screws and motor lead screw assemblies, actuators, cartesian robotics, and mechatronics assemblies.
Smart Manufacturing Technology (SMT) is a world-leading company that supplies unique design tools & engineering consultancy solutions for the design, analysis and development of gearbox & transmission systems for the automotive, wind turbine, industrial, marine and aerospace industries.
The Tsubaki brand has been globally recognized for its superior power transmission and motion control products. Since 1917, The Tsubakimoto Chain Company, headquartered in Japan, has been moving the needle forward by constantly innovating new products and expanding its global operations.
