PBC Linear is a leader in the engineering, manufacturing, and assembly of a wide range of linear motion products, along with custom engineering services. Our core line of linear components includes bearings, shafting, rail assemblies, and cam roller sliders. Building on this strong foundation, we have created a sophisticated family of products that includes lead screws and motor lead screw assemblies, actuators, cartesian robotics, and mechatronics assemblies.
