» Worm Drives
Companies in Worm Drives
Six Star
SPN Schwaben Praezision
STM Riduttori SpA
Stoffel Polygon Systems, Inc.
Toledo Gearmotor
Torque Transmission
TVT America, Inc.
Var-Spe Variatori Oleodinamici
Varitron Engineering (Taiwan) Co., Ltd
VL Motion Systems Inc.
WEG Cestari Redutores
Yilmaz Reduktor Sanayi ve Tic A.S.
York Industries
Zhengzhou AOKMAN Machinery Co. Ltd.
