» Worms
Companies in Worms
Mini Gears (Stockport) Ltd.
Minsk Gear Works
MMR Precision Gears
Moventas Ltd.
Nichiei Company, Ltd.
Nidec-Shimpo Corporation
Niebuhr Gears
Nuttall Gear (A Regal Rexnord Brand)
Ontario Gear and Spline
P. G. DRIVE
Perry Technology Corporation
PIC Design
Power Electric
Precipart
Precision Technologies Group (PTG) Ltd.
Prozamet
PST Group (MTI Motion)
7
