» Worms
Companies in Worms
Global DriveTrain, Inc.
Havlik Gear
Hoffmann Technics AG
Houston Pump and Gear
I-MAK Reduktor
Intech Corporation
Involute Powergear Pvt. Ltd.
JVL Industri Elektronik A/S
KHK USA Inc
Kisco Gears
Koro Industries, Inc.
Li Gear
Malkar Industries
Marshall Engineering Works
Martin Sprocket & Gear
MIJNO-USA
7
