» Segments
Companies in Segments
PIC Design
Precipart
QTC Metric Gears
Rush Gears Inc.
SPN Schwaben Praezision
ST Gear & Machine LLC
Supreme Gear Co.
Trojon Gear Inc.
Victrex Gear Solutions
WMH Transmissions Ltd
