» Ring Gears-Spur or Helical
Companies in Ring Gears-Spur or Helical
Gear Motions, Inc.
GearTec
Global DriveTrain, Inc.
GNA Gears
Houston Pump and Gear
IGW Industry Division
KHK USA Inc
Koro Industries, Inc.
Li Gear
Mini Gears (Stockport) Ltd.
Minsk Gear Works
MMR Precision Gears
Moventas Ltd.
NDE Clarke Pitchline Ltd
Nichiei Company, Ltd.
Nidec-Shimpo Corporation
