» Internal Gears
Companies in Internal Gears
Agro Engineers
Allied Gear Co.
Allied Specialty Precision Inc.
American Gear & Engineering
American Gear, Inc.
Ancon Gear & Instrument Corp.
Atlantic Sintered
Avion Technologies Inc.
B&B Manufacturing, Inc.
Baart Industrial Group
Bison (Ametek)
Brad Foote Gear Works, Inc
Buffalo Gear, Inc.
Butler Gear
C-B Gear & Machine, Inc.
Carnes-Miller Gear Co., Inc.
7
