» Automotive Gears
Companies in Automotive Gears
GearTec
GKN Automotive
Global DriveTrain, Inc.
Havlik Gear
Hero Motors
Koro Industries, Inc.
Maxon Precision Motors
NDE Clarke Pitchline Ltd
New Allenberry Works (Deepak Industries Ltd.)
Nichiei Company, Ltd.
Ontario Gear and Spline
P. G. DRIVE
Perry Technology Corporation
Pragati Transmission Pvt Ltd
Prozamet
