» Gear Drives
Mechanical devices whose function is to alter the speed, torque and/or direction of rotating shafts.
Companies in Gear Drives
Bevel Gears India Pvt. Ltd.
Bierens Machinefabrieken B.V.
Bodine Electric Company
Bonfiglioli Riduttori S.p.A.
Bonfiglioli USA, Inc.
Bosch Rexroth
Boston Gear
Brad Foote Gear Works, Inc
Buehler Motor, Inc.
C-B Gear & Machine, Inc.
Central Gear & Machine
Chenta Gear USA
Cincinnati Gearing Systems
Cleveland Gear Co.
Cogmatic
Columbia Gear Corp.
7
8
9
13
14
