» Gears
Gears are toothed wheels that provide for the transfer of rotary motion from one shaft to another (or rotary-to-linear motion in the case of racks), as well as speed increase or reduction from one shaft to another.
Companies in Gears
Area Distributors Inc.
Arnold Magnetic Technologies
Artec Machine Systems
ASCO Sintering Co.
ASI Drives
ATA Gears Ltd.
Atlanta Drive Systems Inc.
Avers Machine and Gear dba Innovative Rack & Gear
Avion Technologies Inc.
B&B Manufacturing, Inc.
Baart Industrial Group
Bartlett Bearing Company, Inc.
Bearing Engineering Company
Bearings Limited
Befared
7
8
9
14
15
