» Couplings & U-Joints
Mechanical devices used to connect and transmit motion between rotating shafts, often allowing for shaft misalignment and overload protection.
Companies in Couplings & U-Joints
Moventas Ltd.
MW Components
NDE Clarke Pitchline Ltd
New Power Electric (USA) LLC
Nu-Teck Couplings Pvt. Ltd
OEP Couplings, a Division of Oren Elliott Products
Ondrives US Corp.
Orttech
Pacific Industries
PIC Design
Pinpoint Laser Systems
Pix Transmissions Limited
Radicon Drive Systems, Inc.
René Baer AG
Renold Ajax
7
8
9
10
