» Couplings & U-Joints
Mechanical devices used to connect and transmit motion between rotating shafts, often allowing for shaft misalignment and overload protection.
Companies in Couplings & U-Joints
Bevel Gears India Pvt. Ltd.
Bibby Turboflex
Boston Gear
BRECOflex CO., L.L.C.
BSF, Inc.
C R Products Ltd.
C-B Gear & Machine, Inc.
C-Flex Bearing Co., Inc.
Canto Engineering Company
CCTY Bearing
CENTA Power Transmission div. of Rexnord
Chengdu Talent Industrial Co., Ltd.
ComInTec
Cross + Morse
7
8
9
10
