» Controls
Electric and electronic components used to control the speed and operation of motors and other power transmission equipment.
Companies in Controls
HPB Motion Control Co. Ltd.
I-MAK Reduktor
Industrial Automation Co.
Inertia Dynamics, Inc.
Intellidrives, Inc
JVL Industri Elektronik A/S
K+S Services
KB Controls
KEB America, Inc.
Kollmorgen
Leeson Electric
Lenze Americas
Logan Clutch Corp
Magtrol, Inc.
Marshall Wolf Automation Inc.
7
8
