» Clutches
Mechanical components used to engage and disengage driving and driven shafts.
Companies in Clutches
Marine Specialties, Inc.
Marshall Wolf Automation Inc.
Matrix International
Mayr Corporation
Means Industries, Inc.
MES INC
Midwest Brake
Miki Pulley US
Moventas Ltd.
Mubea
New Torque, Inc.
North American Clutch & Driveline
Ondrives US Corp.
Orttech
PEACO Support Inc
PIC Design
