» Clutches
Mechanical components used to engage and disengage driving and driven shafts.
Companies in Clutches
Howdon Power Transmission Limited
Huco (A Regal Rexnord Brand)
Inertia Dynamics, Inc.
J.W. Winco Inc.
jbj Techniques Limited
KBK Antriebstechnik Gmbh
KEB America, Inc.
Kraft Power Corporation
KTR Corporation
Logan Clutch Corp
Mach III Clutch Inc.
Magnetic Technologies Ltd
Magtrol, Inc.
Marine Specialties, Inc.
Marshall Wolf Automation Inc.
