» Belting & Belt Drives
Belts, made of loops of flexible material, are used in conjunction with pulleys to create belt drives, allowing the transfer of rotary motion from one shaft to another.
Companies in Belting & Belt Drives
Boca Bearing Company
Bonfiglioli USA, Inc.
Bowman Hollis Mfg
BRECOflex CO., L.L.C.
Brewer Machine & Gear Co.
Butler Gear
C R Products Ltd.
Canto Engineering Company
Capstan Atlantic
Carnes-Miller Gear Co., Inc.
Chemi-Flex LLC
Chirala Beltings
Cincinnati Gearing Systems
ComInTec
Comtec Mfg., Inc.
7
8
9
10
