» Actuators
An actuator is a device that accepts some type of input (mechanical, electrical, hydraulic or pneumatic) and produces a mechanical response--usually linear or rotary motion.
Companies in Actuators
Anaheim Automation, Inc.
Anuze Motor Smartech Co. Ltd.
Arnold Magnetic Technologies
Atlanta Drive Systems Inc.
ATO Inc
Avion Technologies Inc.
Bearing Engineering Company
Befared
Bevel Gears India Pvt. Ltd.
Bharat Gears Ltd.
Bishop-Wisecarver Corp.
Bosch Rexroth
Buehler Motor, Inc.
Cablecraft Motion Controls
Central Gear & Machine
7
