In the selection of lubricating greases for plastic worm gears, the user needs to know the influence of each grease constituent on the tribological performance in order to choose the appropriate lubricant. In this work, the effect of NLGI class, viscosity, base oil and thickener type are investigated separately regarding the efficiency and temperature close to the tribocontact. With the help of this contribution the user understands the effect of each parameter and learns about the potentially reachable efficiency and temperature ranges.
In this study, a finite volume CFD simulation model of a single-stage injection-lubricated test gearbox was applied to investigate its oil flow and no-load power loss. The results provide physically plausible information on the oil supply and its distribution.
The proof of the reliability of a gear drive is now an additional requirement. In Europe, the acceptance authorities for wind turbines are requesting a system reliability proof from gearbox manufacturers. The AGMA committee reviewing the AGMA 6006 standard for wind turbines is considering adding a chapter about design for reliability. However, reliability considerations are not new; NASA, for example, was in the 1980s using reliability concepts for gear drives.
For a maintenance crew, it is important to know which bearings need re-lubrication and make sure they are lubricating those bearings. The bearings can be lubricated manually or by automatic lubrication systems. This article
will review each method and discover its pros and cons.
Rolling element bearings are widely used in mechanical transmission to reduce friction between two rotating parts. With the further development of the electrical motor in mechanical industry, REBs operate more and more at high rotational speed. For these applications, REBs power losses can
be predominant in mechanical transmissions.
Cylindrical gear design can be divided into three steps. In the first step, rough gear pair dimensions such as center distance and face width are being estimated. Center distance and face width are directly linked to the available space (housing dimensions) and influence the overall size, weight and cost of the gears.
