If torque conversion with high gear ratio, compact installation space and 90-degree axis-crossing angle is needed, often worm gears are used. Due to their high power density and sliding speeds within the tooth contact, frictional heat and thermal stresses are higher compared to helical, bevel and hypoid gears, and thus the thermal load capacity of worm gears is lower.
Motion control systems often combine high power drive signals in close proximity (or even within the same cable) with lower level signals, like encoders. You will often see ferrite beads added around cables; their effectiveness in minimizing noise is greatly affected by how they are deployed. This involves which signals are grouped, what are the drive characteristics, and how shielding and grounding are handled in the system.
Three-dimensional finite element analysis (FEA) simulation and research from published information is used to compare the features of various coil configurations.
These versatile, low-cost and high-torque motors may be used open loop or as full servos - and several levels in between. The motor stator laminate designs divide these motors into those optimized for full stepping, and those optimized for micro stepping and servo operation. These differences can be easily measured with basic meters and oscilloscopes. Motor to motor variations can also be easily measured, and motor inductance at nominal speed and current can also be determined.
Rolls-Royce is pioneering the UltraFan engine family architecture containing a planetary gearbox in a power range of 15 to 80 megawatts. To increase the efficiency of the UltraFan, a planetary gearbox is introduced between fan and intermediate pressure compressor. This enables running the turbine to rotate faster and allows a reduced fan speed.
The load carrying capacity of spur gears may be calculated by ISO 6336 using influence factors. The face load factor considers the impact of the non-uniform load distribution over the face width. Even if the gears had perfect geometry, the load would not distribute uniformly along the contact lines. The face load factor depends on deformations of all parts of the containing gearbox and mainly of the teeth, gears and shafts as well as on manufacturing and assembly deviations.
In planetary gear systems of high power density and high gear ratio, helical gears create undesirable tilting moments on the planet gears; therefore, spur gears are still preferred for planetary gears -- a special challenge with respect to noise. Specifically, the different behavior of planetary gears with sequential and symmetric gear mesh is explained in this paper.
The integration of manufacturing information into gear design software reduces cost during the design process by avoiding time-consuming back and forth between the design and manufacturing departments. The challenging task for such software is ensuring the
design engineer does not need specific manufacturing expertise. Otherwise he or she would be overwhelmed and not use such a feature.
