When motion system designers need complex, high-speed, multiaxis motion, they might first think of elaborate, prepackaged robot arms. Or, if they need only a few axes, they might configure a separate profile or round rail for each axis. But hiding between those options is simple and proven ball spline technology. This multiaxis motion solution has existed for years and is still highly relevant to today’s complex motion schemes. Ball splines use a unique architecture integrating rotary and linear motion on a single shaft. This gives them more flexibility to implement complex motion schemes in tighter spaces, providing a two-for-one deal in motion control.
The cylindrical die rolling process can produce helical, axial, and annular forms on shaft-like parts at high rates of speed with precision tolerances.
Why use the rolling process to produce high accuracy lead screws, actuator screws, and other power transmission components rather than traditional cutting processes such as turning, grinding, milling, whirling, or hobbing? Rolling processes and cutting processes both produce a precise form on the workpiece. But if the form geometry, tolerances, and material selection allow, rolling is the process to beat. Speed, surface finish, fatigue strength, precision, dimensional stability, and material savings are some of the primary advantages realized when the rolling process is applied.
Randy Stott, publisher of Power Transmission Engineering and Gear Technology magazines, recently sat down with Norm Parker, technical fellow and technical manager for Torque Transfer Systems at Stellantis, to discuss bearing technology during the Motion + Power Technology Expo in Detroit.
This report derives the equation for relative elastohydrodynamic lubrication (EHL) film thickness. Mineral (MIN), polyalphaolefin (PAO), and polyalkylene glycol (PAG) lubricants with viscosity grades of ISO 320, 150, and 32 are analyzed.
More energy efficiency, higher performance and better controllability are the main reasons why more electric drive systems are being operated with frequency converters. However, these devices can cause high-frequency, asymmetrical interference currents, which, as a current passage through the output and fan-side bearings, can cause damage and premature failure.
Current-compensated CoolBlue toroidal cores made of Magnetec’s nanocrystalline material Nanoperm have proven to be effective protection against such conducted interference and its consequences. In addition, the Nanoperm Line Absorbers NaLA can also be used to significantly suppress symmetrical interference currents.
This review of Ref. 1 summarizes the conclusions of test data and numerical simulations showing that Stribeck curves for counterformal contact are different from Stribeck curves for conformal contact.
Technical sales personnel use intelligent features to select suitable motor-gearbox combinations and run calculations based on customer-specific operating data. This provides obvious added value for the customer. Service lives, safeties, and expected loads can all be determined in a short time. Maintenance of the underlying database and the use of simulation tools make it possible to quickly and easily perform technical calculations without having to rely on a central calculation department. In less than a minute, the customer is provided with a data sheet which includes reliable statements about the gearbox based on these technical calculations.
