Standardized calculation methods such as ISO 6336 and DIN 3990 already exist to determine the load distributions on gears inside a planetary gearbox, but by their very universal nature, these methods offer varying results depending on the gearbox design. Double helical gears, in particular, can benefit from more specific, complex algorithms to reach a maximum level of efficiency. Double helical gears interact with the rest of the gearbox differently than helical or spur gears, and thus benefit from different analytical models outside the standardized methods. The present research project describes the algorithm to determine the load distribution of planetary gearboxes with double helical gears.
In the process of applying industrial drive products, we occasionally are misled into believing that we are applying horsepower. The real driving force is not horsepower - it is torque. This paper is developed to impart a deeper understanding of torque, its relationship to horsepower, and the types of loads we most frequently encounter.
Large hydraulic cylinders (LHCs) are integral components in the functioning
of large machines in mechanically demanding, corrosive and abrasive environments, such as offshore drilling rigs. The materials utilized in these largescale hydraulic systems must deliver reliable performance throughout their expected lifecycle.
Reliability and maintenance engineers can improve uptime and save money on both long-term maintenance and downtime costs by properly diagnosing and correcting bearing vibration issues when they exceed their acceptable limits. This requires inspecting the housing as well as the liner for wear, and replacing them as a pair when the housing is worn, so that wear-in between the mating surfaces can occur.
Three electric motor repair facilities share best practices for utilizing copper in motor repair, and recommending new
motors to replace older, less-efficient motors
The SKF Generalized Bearing Life Model is (GBLM) an innovative new bearing rating life model that is designed to help engineers calculate bearing rating life in a more realistic manner. The new model is a major step forward for the industry and will play an important role in enabling OEMs and end users to better match bearings and applications, resulting in improved machine life and reduced operating costs.
Design engineers across industries rely on pillow block bearings for a variety of tough and unconventional applications. Having access to data that backs housing strength performance claims is an integral part of choosing the right bearing to keep operations running optimally. What design considerations must be made when the application demands a pillow block installation on a non-horizontal
orientation? What happens when bearing load is not applied through the base of the unit? Timken answers these questions with physical testing, advanced modeling and real-world experience to facilitate the selection of pillow block bearings for specific applications.
