Let's start with why field weakening is useful: it produces a wider speed range for a motor - with a constant torque at lower speeds and an almost constant power capability at higher speeds.
I have a problem with a disc flexible shaft coupling that is used in screw compressors. This coupling is cracked and damaged after a short time, and the changing rate of this coupling is very high — about every 3 months. But as I understand from the machine manual, the coupling replacement may be every 8,000 hours or 12 months...
On the tradeoffs between power density, efficiency and cost for high-performance, electric motors in choosing the most applicable technology for a specific application.
The main function of rolling bearings is to support load and transmit rotational movement with minimum energy loss. In order to achieve this, bearings are manufactured with particularly good quality fatigue resistance materials, proper design and tight manufacturing tolerances. Particular emphasis is put in both the macro, and micro geometry of the working shapes and surfaces of the raceways. Rolling bearings come in many types and sizes as ball and roller bearings for radial and thrust loads.
