BorgWarner Inc. offers clean and efficient technology solutions for combustion, hybrid and electric vehicles. With manufacturing and technical facilities in 66 locations in 17 countries, the company employs approximately 29,000 worldwide. (www.borgwarner.com)
Continental's Powertrain division develops and produces efficient system solutions for vehicle powertrains to optimize fuel consumption. The comprehensive range of products includes gasoline and diesel injection systems, engine management and transmission control, including sensors and actuators, exhaust-gas after -treatment technologies, fuel supply systems, and components and systems for hybrid and electric drives. (www.continental-automotive.com)
Dana supplies highly engineered driveline, sealing, and thermal-management technologies that improve the efficiency and performance of vehicles with both conventional and alternative-energy powertrains. Serving three primary markets — passenger vehicle, commercial truck, and off-highway equipment — Dana provides the world's original-equipment manufacturers and the aftermarket with local product and service support through a network of nearly 100 engineering, manufacturing, and distribution facilities. (www.dana.com)
Delta Research offers prototype and production transmission components and assemblies. Throughout its 65 year history, the organization has increased its capabilities for high-precision gears, shafts, carriers, machined housings and inspection services. (www.deltaresearch.com)
Product Innovations
CTI Symposium USA holds the Transmission Expo during the week, featuring 80+ exhibitors and 700+ attendees to showcase transmission and powertrain technologies. Here are some of the technologies that will be featured at the show:
Torque Sensors from Methode Electronics Inc.
Magnetoelastic sensors are the first solution that allows measuring torque and other forces economically so that it can be integrated into high volume applications. The current status quo for force measurements — strain gauge type sensors — require extensive manual labor during application, fault susceptible telemetries and recalibration due to aging effects, making them expensive and difficult to integrate.
Magnetoelastic sensors have a number of advantages that make them ideal for high volume production applications. The technology has a small space requirement and the sensing object (e.g. driveshaft) does not need to be modified. There is no need for telemetry which makes the technology true NON-contact. Magnetoelastic sensors has exceptional long term stability and have proven their performance in many high volume applications over more than the last 10 years beside automotive in eBikes, electronic power steering and agricultural. (www.methode.com)
Hoerbiger TorqueLine Twin Cone & Disconnect Clutch
The TorqueLine Twin Cone replaces traditional multi-disc clutches, reducing drag losses by as much as 90 percent. The system offers high power density and decreases actuation forces by up to 60 percent. The TorqueLine Disconnect Clutch, optimizes drag losses by combining a traditional multi-disc with a conical friction based disconnect system: the clutch disc carrier is connected and disconnected by an integrated presynchronization element. (www.hoerbiger.com)
Nitriding and Coating Technologies with RÜBIG Industrial Furnaces
RÜBIG Industrial Furnaces is a globally active producer of customized heat treatment plants (plasma/gas nitriding and plasma coating). The Know-how reflected in the systems has been gained in the in-house job shop. With their Micropuls and Gascon technologies, RÜBIG offers the latest in nitriding and coating technologies. (www.rubig.com)
Future for Mobility
How will technology change for automatic, HEV, EV Drives? The CTI Symposium offers the technical knowledge, market strategies and international developments on transmissions and powertrain components to answer this question. From the electrification of automobiles to the quest for optimum fuel efficiency, this event will provide a roadmap to the future of the automotive industry.
Car Training Institute (CTI)
Phone: +49 (0) 2 1196 86-3000
www.transmission-symposium.com/usa
