The need for producing more energy increases with our rising need for commercial, industrial, and residential space. In North America (including the U.S., Canada, and Mexico) alone, power transmission market estimates at a whopping $70.4 billion, according to a recent report.
In any industrial facility, turbines and motors are used to produce rotational mechanical motion to perform different kind of tasks. The industrial power transmission market works with basic power transmission open-drive products like belt drives, chain drives, gear drives and each has its own set of advantages and disadvantages. In this post, we will look into the pros and cons of these components of power transmission technology.
Belt Technology
One of the most common devices, belt drives are used to transmit motion from one shaft to another with the help of a thin inextensible band that runs over two pulleys. It is basically a looped strip of flexible material that mechanically link the rotating shafts.
There are various kind of belt drives available in the market such as flat belt, V-belt, rope drive, and timing belt. It is important to select the right kind of belt drive, depending upon:
Power to be transmitted
Direction of belt motion
Shaft’s velocity and Velocity ratio
Service conditions
Distance between shafts, and space available
Irrespective of the type of belt drive you are using, this technology offers a smooth and effective transmission of power between shafts even if they are at a considerable distance. This technology is used when you need to transmit rotary motion between two parallel shafts. They are the cheapest method of power transmission.
The advantages of a belt drive include:
Belt drives are cost-effective. New belt drive efficiency can be up to 95-98 percent
They are simple to use
Belt drives do not require parallel shaft
They have a low maintenance cost
They come with overload and jam protection
Different speeds can be obtained by means of step or tapered pulleys
When the distance between shafts is very large, belt drives are the most economical options
Damp out noise and vibration
Load fluctuations are shock-absorbed, increasing the machinery life
Clutch action can be activated by releasing belt tension
However, belt technology also comes with certain disadvantages. These are:
Belt drives are not compact
Limited speed of around 35 meters per second
Compared to other mode power transmission, they have a short life service
Typically, its operating temperatures are restricted to –35 to 85°C
Angular velocity of belt drives isn’t constant. This leads to stretching, slipping, and wearing of belt
It has limited power transmission of up to 370 kW, which increases the heat build-up
Belt drives usually inflict a heavy load on shafts and bearings
For wearing and stretching compensation, they additionally need an idler pulley or some adjustment of center distance
The velocity ratio varies because of belt slip
Chain Technology
As the name suggests, chain drives come with an endless series of chain links with a net of toothed sprockets. Unlike belt drives, there is no slip in chain technology. However, they are mostly suited for small centre distances, usually up to 3 metre. In some special circumstances, chain drives can even cover a distance of up to 8 meter.
This technology is used for performing three basic functions. These are:
Transmitting power: They can transfer power (speed and torque) from one component to another by means of a linked chain and sprockets. Chain drives can transfer a large amount of torque even within a compact space.
Conveying materials: They can move, carry, slide, push, and pull various materials by attaching buckets, frames, pockets, or meshes to the chains. They are often used for turning rollers to move a conveyor belt.
Timing purposes: Many industries use them to synchronize or time movements.
Just like any other type of mechanical transmission systems, chain drives also have several advantages and disadvantages. The advantages include:
Positive drives with no slip or creep
Unlike belt drives, angular velocity remains constant in chain drives
High-velocity ratio of up to 8:1
It allows high speed ratio of 8 to 10 in one single step
Highly efficient, chain drives gives the advantage of more power compared to belts
It can be used for both small and large center distances
More compact and are easy to install compared to belt drive
Chain drives do not deteriorate due to sunlight, oil, grease, or age
Lower load on shaft than belt drives
The disadvantages of chain drives
The initial cost of installation is higher than belt
The production cost is also relatively higher
Chain drives need regular lubrication
Driving and driven shafts must be perfectly aligned and parallel
They can have velocity fluctuations when unduly stretched
Not suitable for applications where it is necessary for the drive to slip
Chain drives are noisy and can also cause vibrations
They have lower load capacity and service life compared to gear drives
Gear Technology
In the world of mechanical power transmission, gear drives have a very special and prominent place. This is the most preferred technology when you need to transmit considerable power over a short distance with a constant velocity ratio. The mechanism of gear drives is quite simple – the teeth, which are cut on the blanks of the gear wheel, mesh with each other to transmit power. To avoid slipping, the projections on one disc mesh with the recesses on other disc in gear drives.
This technology uses different types of gears for power transmission. In fact, it can transmit power not only between parallel shafts, but also between non-parallel, co-planar, and intersecting etc. shafts.
The following are the advantages of gear drives:
They are positive and non-slip drives
Large and constant velocity ratio of 60:1 can be obtained by using gear trains with minimum space
Gear drives are mechanically strong, allowing scopes for lifting higher loads
Longer service life compared to both belt and chain drives
They can transmit large power
Gear drives have high transmission efficiency
They can transmit motion over small centre distance of shafts
These drives are ideal for low, medium, high power transmission
Gears can transmit motion even between non-parallel intersecting shafts
These are the most compact compared to belt and chain drives
Unfortunately, gear drives too have certain disadvantages:
Gear drives cannot be used for shafts with large center distances
They are not ideal for large velocities
These drives require regular lubrication and a more complicated process of applying it
Noise and vibrations are increased at a high speed
They are less economical compared to belt and chain drives
Using multiple gears increase the machine’s overall weight
They have no flexibility
Not suitable for transmitting motion over a large distance
Some part of the machine can get permanently damaged because of the toothed wheel of gears. This is more common in case of excessive loading
Conclusion
Energy is essential for driving the machines and equipment for various applications. Different industries use different power transmission products and sometimes a combination of all to suit their respective needs. So if someone ask which is the best power transmission technology, it will be little difficult to select one over another as these drives come with their own sets of pros and cons. The only determining factor, therefore, should be the task that needs to be accomplished using the power transmission technology. And of course, the budget too.
About the Author: Jack Warner is a tech enthusiast who likes to stay updated with the latest norms in the technology world. He writes for Power Jack Motion, a company which manufactures and supplies motion control components.
