Today’s competitive industrial gear marketplace demands products with excellent reliability, high capacity and low noise. Surface-hardened, ground tooth gearing predominates, but the legacy tooth forms handicap further improvements in capacity and noise generation. Vehicle and aircraft equipment use tooth forms not found in the standard tables to achieve better performance — with little or no increase in cost. This paper will propose adopting these high-contact ratio forms to industrial use.
Spiroid and worm gears have superior advantages for hightorque and miniaturization applications. And for this reason they are particularly preferred in aerospace, robotic and medical applications. They are typically manufactured by hobbing technology, a process with a typical overall lead time of 4 to 14 weeks.
A four-point contact ball bearing makes it easy to simplify
machine designs that combine radial, thrust and moment
loads, because it can handle all three simultaneously. They
are primarily used for slow-to-moderate-speed applications,
or where oscillatory movement is predominant.
Bellows couplings first began to be
widely used by machine tool builders
in the mid-to-late 20th century. With the
advent of CNC technology, machine
engineers started looking to improve
upon some of the negative influences
traditional power transmission couplings
can have on a precision rotary /
linear motion system.
The use of motor current signature analysis (MCSA) for motor fault detection — such as
a broken rotor bar — is now well established. However, detection of mechanical faults
related to the driven system remains a more challenging task. Recently there has been a growing interest for detection of gear faults by MCSA. Advantages and drawbacks of these
MCSA-type techniques are presented and discussed on a few industrial cases.
Wear is a very important topic for dry running plastic gears. Over the past few years,
the authors have worked closely with a number of manufacturers of plastic gears
to investigate the problems of gear wear in detail. Together they have developed a calculation method that can be used to predict where and when local wear will occur on a tooth flank. Their findings have also just been published in the final version of VDI 2736.
When comparing bearing suppliers,
engineers are often left with few options
other than to compare dynamic
load ratings and corresponding life
calculations. Of course, we can look at
steel and manufacturing quality; but
if we are comparing sources of similar
quality, those items may not provide
a large contrast. It often surprises
people to learn that bearing capacities
are calculated values, not tested values.
Lately, however, a trend is emerging
for bearing suppliers to increase their
ratings for higher performance bearings
that have premium features such
as higher quality steel and specilaized
heat treatment. Bearing companies are
under intense competitive pressure to
make every feature add to the dynamic
capacity of their bearings because it is very well understood that an increase in capacity adds to the bottom line.
