In 1991, Needelman and Zaretsky presented a set of empirically
derived equations for bearing fatigue life (adjustment) factors (LFs) as a function of oil filter ratings.
Tapered roller bearings can be set at initial machine assembly to any desired axial or radial clearance. This unique feature enables a designer to control bearings to meet anticipated application operating conditions, and thereby provide
optimum bearing and system performance.
When talking about high-end machining or manufacturing applications that include direct-drive technology, one of the key advantages of utilizing this particular transmission method is its endurance. Because of the very nature of direct-drive motors they are able to operate at peak performance levels indefinitely — without any kind of wear or aging — as long as the motor isn’t pushed past its capacity.
Unfortunately, because this isn’t a perfect world, unexpected things can happen which can cause the motor to overheat. Whether the heat source is due to a parameter being input incorrectly, or an unexpected external force causing more resistance than expected — it is important to have certain forms of thermal protection in place. Since torque motors are built in such a way that they cannot be
repaired and yet maintain their efficiency, it is vital to prevent any overheating — thus precluding the
need to purchase a new one.
One of the key challenges in the mining
industry today is maintaining throughput
in the face of ore grade quality that
has declined by 40 percent in the last
decade.
