The purpose of DC motor protection is
to extend a motor's lifespan by protecting
it from conditions that can damage the motor's windings--both electrically
and mechanically.
The development of a new, gas-carburized gear steel, necessitated by a customer-driven specification, has not only increased the power density in an existing gearbox design, but has done so without requiring any significant change to production processes or heat treatment equipment.
This paper is intended to enlarge the application range of radial cylindrical roller bearings by means of a more precise determination of thrust load capacity and more cost-effective design.
Q&A: My company manufactures high-speed metal forming machines. We have one application on a feed axis where we are encountering problems with the coupling...
This paper is part 2 of 2 in a series that summarizes the chemical, metallurgical and physical aspects of bearing steels and their effect on rolling bearing life and reliability.
