Thomson Industries, Inc., a leading manufacturer of linear motion control solutions, has introduced a family of compact linear systems that makes it easier for motion designers to implement complex applications in small spaces. Designers needing thrust and bearing support in a single, compact unit now have the flexibility to build such applications with versatile, time-tested components from Thomson.
For nearly 50 years, AJD Forest Products has been producing top quality industrial lumber for the Lake States region. Located in Grayling, Mich., the company has earned a reputation for supplying high-grade red oak, hard & soft maple, aspen, ash, and basswood. The mill processes 1,700-2,000 logs, or 70,000-90,000 board feet of lumber a day, but constant maintenance and adjustment on their stacker and chain conveyor brakes were forcing unplanned downtime.
Intellidrives EtherNet/IP compatible Motion is a scalable and comprehensive solution that provides a common application interface and services for general purpose I/O and motion control that is fully compatible with standard Ethernet/IP topologies, minimizing integration effort with Ethernet/IP-based PLCs.
MagnaShear motor brakes, which provide a secure, no-maintenance, no-adjustment, holding brake solution for mining conveyor applications will be featured at MinEXCHANGE Booth #2720.
Heidenhain will be exhibiting at Photonics West, Booth #3053, on January 28-February 2 in San Francisco, Calif. Heidenhain will showcase the latest MULTI Degrees-of-Freedom (MULTI-DOF) motion control components, offering manufacturers a better way to implement metrology designs. Photonics West is the world’s premier lasers, biomedical optics and optoelectronics event.
Binder USA has developed a complete portfolio of connectors, contacts, tools and accessories for crimp termination. Binder’s crimp variants simplify wiring for quick cable assembly on site.
The Timken Company recently announced its packaged wheel bearings are being used on Ford Motor Company's F-150 Lightning, the first mainstream electric light-duty pickup truck to hit the market. Timken bearings on the F-150 Lightning represent incremental content per vehicle, compared to its gasoline-powered counterpart.
