Rolling bearing life depends on the contact stresses that occur between the rolling elements and the raceways. Contact stresses are calculated from contact loads, which in turn depend on the external loads acting on the bearing and the precise internal geometry of the bearing.
How can the protective layer be applied to the brake disk more quickly and more effectively? And how can it be made to stay on for longer? “The solution is intelligent coatings, as can be applied to brake disks using our AM coating system” says Dr. Géza Koscsák - the head of additive mat the Chiron Group. He has played a prominent role in developing the new system and reaching the decision to opt for the high-speed deposition welding process in his previous job as head of advanced development.
One of the world’s top fertilizer producers operates a big fertilizer complex in South America. A few years ago, the company started an expansion project that includes three additional phosphoric acid concentration lines. Sulzer was selected to supply the critical evaporator circulation pumps.
ZF presents the latest generation of electric drives for passenger cars and light commercial vehicles. It sets standards through outstanding power density and energy efficiency. ZF achieves this thanks to numerous innovations at both the component and system level. These include the compact design of the drives, the "discrete approach" in power electronics, and a resource-saving use of materials, which also makes the production of the drives more sustainable. With their modular concept, the new ZF e-drives support automotive manufacturers in customizing the further electrification of their entire model range. For end customers, the new technologies offer higher efficiency, more power, and shorter charging times.
esco, technology partner for process digitization in the gear and cutting tool industry, is expanding its software offering with the new eSkiving.FS module for effective feasibility studies in gear skiving. At the same time, the company is introducing ePP, a comprehensive software platform that includes eSkiving.FS to provide seamless support in all areas of the gear skiving process.
The team at the David Brown Santasalo (DBS) purpose-built state-of-the-art facility in Jyvaskyla, Finland were delighted to have a further opportunity to work with Europe’s largest iron ore producer, manufacturing another impressive segmented ADI (Austempered Ductile Iron) girth gear.
The new AT20-600 series of Motorized Vertical Lift Stages from Optimal Engineering Systems, Inc. (OES) features a vertical lift of 600 mm. The AT20-600-01 (pictured) is driven by a Two-Phase Stepper Motor features a repeatability of 5 microns, positional accuracy of 20 microns and has a knob on the motor for manual adjustment.
Adjusting a stop and hold position in an automated system is made easy using Miki Pulley BXW brakes with the manual release lever feature. It allows the operator to depress the lever and make a manual adjustment when the system is powered off. The lever also allows easy system indexing in the event of a power failure.
