Gears and gear racks used for transmitting torque and forces within gearboxes are typically made of hardened steel. For many other uses and applications, gears and racks made from plastic are the better choice. These generally require no lubrication and are lighter, quieter, less expensive, and more resistant to corrosion than metal gears. This is why JW Winco is expanding its range with polyamide gears and racks that can transmit high forces and torques.
The demand for a high accuracy, robust, open-frame stages is met with Intellidrives dual-axis, large aperture stages that address the unique needs of scanning microscopy, wafer and printed circuit board inspection, automated assembly and wide range of specimens and samples scanning in many types of imaging techniques and applications.
Drop-in system offers tightest inner radius in the market for reduced footprint
February 8, 2023
Regal Rexnord Corporation introduces its new Rexnord Curve System with 1540 Series MatTop Chain for conveyor lines requiring a zero tangent 180 and/ or 90-degree curve. The system offers the tightest inner radius (420 mm) and smallest transfer (15 mm) in the industry, for greatly improved space utilization and package handling.
Commercial garage doors range in many sizes and configurations requiring a “just right” model and size brake for reliable automatic operation. Depending on the design and size of the overhead door and placement of the brake, a variety of brake models and sizes offer solutions from the Miki Pulley brake lineup.
