At this year’s Hannover Messe, NKE Austria GmbH will present bearings for wind turbine gearboxes and generators. The Austrian bearing manufacturer has more than 20 years of experience in the wind energy sector. NKE bearings have been installed in more than 4,000 wind turbines across Europe, the USA and China, equivalent to more than 10,000 MW of installed power.
A high force Linear DC servomotor from Moticont has been added to their expanding line of voice coil or moving coil motors. The LVCM-095-038-01 Linear Voice Coil Motor is a true servo motor featuring zero cogging, high accuracy, and high repeatability when operated in a closed positioning loop
Rollon, a global manufacturer of linear motion and gantry systems, has introduced its lightweight MiniRoller Rail linear bearing. Ideal for applications that require moderate loads, it features super smooth and silent operation and an adaptive design that is easy to customize and integrate into assemblie
SKF has developed a composite bushing for motorcycle front suspensions (or forks) that reduces the need for maintenance. A combination of metals, plus a lubricating coating, gives the bushing both mechanical strength and low friction.
Binder USA offers M12 connectors with all external parts – threaded locking ring, housing, and pressing screw – constructed of stainless steel. The cable clamp is constructed of PTFE, the seal is made of Viton, and rounded surfaces facilitate cleaning.
