Mitsubishi Electric Automation, Inc. announces the upgrade option of Vibration Cutting Control (VCC) via hardware to its M8 Series CNC as a solution to eliminate chip strands while machining difficult to cut material, such as stainless steel, at faster cutting speeds.
FDA/USDA certified, two, three and four post, stand-off bearing flange blocks are setting a new standard for performance and hygienics. These new stand-off bearing flange blocks now available from LM76 reduce the surface area where mold and bacteria can thrive, even from the most through sanitizing operations. Long life hybrid stainless steel Si3N4 Silicon Nitride ceramic ball bearings in stainless steel bearing blocks are coated with a smooth non-water absorbing polyamide coating certified by EHEDG, USDA, and 3-A. These FDA/washdown flange bearings employ hybrid stainless steel/ceramic ball bearings that are sealed from contaminates and bacteria via a patented shaft seal system. The seals resist water, cleaning solutions - keeping lubrication from being corrupted and evacuated.
Portescap announces the release of the 45ECF brushless DC flat slotted motor, the latest addition to join our flat motor portfolio. The 45ECF features a performance optimized design that utilizes an outer rotor configuration with an overall diameter of 43.2 mm and a body length of only 22.5 mm. The motor features hall sensors to easily control speed and torque and can be provided sensorless based on application requirements. Additionally, the motor can be used in combination with existing gearbox designs to provide high output torque at required operational speeds.
Liebherr expands the existing product portfolio of open circuit pumps by the nominal size of 550 and as a double pump by the nominal size of 1,100 cc (1,100 cm3). Moreover, the new nominal size of 100 adds to the LH30VO family.
Leveraging Dana’s field-proven powershift technology, the eSP502 e-Transmission offers a dual-motor, two-speed design that is built on a flexible platform to enable optimized performance at maximum efficiency in a compact package. The modular approach to the transmission design allows for a single motor solution, as well as an optional power take-off, depending on the specific vehicle requirements. It recently made its North American debut at IFPE 2023.
Hägglunds hydraulic drive systems are a familiar presence in the mining and mineral processing industries, as well as in related materials handling applications. Compact, gearless and utterly reliable, they offer significant advantages over their electromechanical counterparts. Those advantages continue to grow stronger, and the range of possibilities they create is set to expand.
Festo introduces the company’s latest online productivity tool – Electric Motion Sizing – for error-free sizing of linear and rotary electromechanical systems. Electric Motion Sizing improves project efficiency by slashing the engineering time required for identifying and specifying harmonized electric motion systems. Multi-axis handling systems can be specified with Electric Motion Sizing’s sister productivity tool Handling Guide Online, which offers similar benefits.
