Ernest Head (Arnie), CBS and technical
sales representative at Motion Canada
helped save a lumber industry customer
time and money by adapting a bearing
solution for another client. Here’s how:
When trying to find a new bonding material dispense system, one manufacturer tested a series of pumps — all of which leaked due to the abrasiveness of the bonding material. The manufacturer also had been attempting to manage shot size
manually with their previous system, and was not able to keep dispense consistent. The company searched for
a system that could accurately dispense programmed shot sizes while also eliminating the leaking issues they
had experienced with previous pumps. Graco provided a Check-Mate pump with SmartWare software, and the manufacturer is now able to automatically dispense shots of bonding material as small as one ounce without leaks.
slow speed operation.
Increasing pressure on many fronts is compelling mine operators to thoroughly examine every phase of their operations. Fluctuating demand
that whipsaws mineral prices, government-imposed environmental regulations and rising operating costs related to maintenance downtime all pose serious challenges for the mining sector. Add pressure from customers and stakeholders for more sustainable operations as well as union demands for higher wages, and you have a scenario that requires mine operators to exercise every possible option to
achieve more efficient operations.
Rolling-element bearings are high-precision components that need to be stored and handled carefully to perform as designed. Proper storage and
handling of a bearing before, during
and after installation is important because once debris enters a bearing, it
reduces the life.
Experienced operators can often
tell if a machine is not working
properly, on the basis that it does
not ‘sound right.’ The same principle can be applied — using modern electronics — to identify the exact cause of the problem.
Sensitive accelerometers can detect and analyze the vibrations from industrial equipment, highlighting problems such as misalignment
or bearing imbalance. The technique
is known as vibration analysis. It can
identify bearing failure in the very early stages, when there is a microscopic defect on the raceway, for example. The problem is that the
identifying signal is usually drowned out in all the other noise emanating from the machine.
