Specialist power transmission supplier JBJ Techniques Limited, of Redhill, Surrey, England were recently contacted by the staff of Bloodhound SSC R&D engineering team to solve
a problem on the fuel pump test rig. JBJ Techniques had worked with various team members in the past and this previous experience made JBJ an easy choice to assist with this project. The scope of supply was to produce a suitable drive coupling with a maximum diameter of 160 mm, capable of
transmitting 550 Nm @ 10,000 rpm, with as short an assembly as possible, and at the same time be able to accept misalignment within the drivetrain.
Asymmetric tooth gears and their rating are not described by existing gear design standards. Presented is a rating approach for asymmetric tooth gears by their bending and contact stress levels, in comparison with symmetric tooth gears, whose rating are defined by standards. This approach applies finite element analysis (FEA) for bending stress definition and the Hertzian equation for contact stress definition. It defines equivalency factors for
practical asymmetric tooth gear design and rating. This paper illustrates the rating of asymmetric tooth gears with
numerical examples.
Dale Renner, CBS and sales representative at Bearing Headquarters Co., explains how his bearing expertise
helped solve a customer’s problem
and saved significant downtime and
cost.
During the past 10 years, the PM industry has put a lot of focus on how to make powder metal gears for automotive transmissions a reality. To reach this goal, several hurdles had to be overcome, such as fatigue data generation on gears, verification of calculation methods, production technology, materials development, heat treatment recipes, design development, and cost studies.
All of these advancements will be discussed, and a number of vehicles with powder metal gears in their
transmissions will be presented. How the transmissions have been redesigned in order to achieve the required stress levels while minimizing weight and inertia, thus increasing efficiency, will also be discussed.
