The manufacturing process begins in a
limestone quarry. Mining methods such
as ripping, dozing, drilling and blasting are commonly employed. Limestone provides the first essential component, calcium, for the anufacture of cement.
Materials are transported to the
crushing plant for further size reduction. Common methods of transport are trucks, loaders and belt conveyors.
Specialist power transmission supplier JBJ Techniques Limited, of Redhill, Surrey, England were recently contacted by the staff of Bloodhound SSC R&D engineering team to solve
a problem on the fuel pump test rig. JBJ Techniques had worked with various team members in the past and this previous experience made JBJ an easy choice to assist with this project. The scope of supply was to produce a suitable drive coupling with a maximum diameter of 160 mm, capable of
transmitting 550 Nm @ 10,000 rpm, with as short an assembly as possible, and at the same time be able to accept misalignment within the drivetrain.
Asymmetric tooth gears and their rating are not described by existing gear design standards. Presented is a rating approach for asymmetric tooth gears by their bending and contact stress levels, in comparison with symmetric tooth gears, whose rating are defined by standards. This approach applies finite element analysis (FEA) for bending stress definition and the Hertzian equation for contact stress definition. It defines equivalency factors for
practical asymmetric tooth gear design and rating. This paper illustrates the rating of asymmetric tooth gears with
numerical examples.
Dale Renner, CBS and sales representative at Bearing Headquarters Co., explains how his bearing expertise
helped solve a customer’s problem
and saved significant downtime and
cost.
