In the selection of lubricating greases for plastic worm gears, the user needs to know the influence of each grease constituent on the tribological performance in order to choose the appropriate lubricant. In this work, the effect of NLGI class, viscosity, base oil and thickener type are investigated separately regarding the efficiency and temperature close to the tribocontact. With the help of this contribution the user understands the effect of each parameter and learns about the potentially reachable efficiency and temperature ranges.
In this study, a finite volume CFD simulation model of a single-stage injection-lubricated test gearbox was applied to investigate its oil flow and no-load power loss. The results provide physically plausible information on the oil supply and its distribution.
Downtime, downtime, downtime. When it's
planned, it's bearable. When it's not, it's not. To maintain machinery, planned downtime is necessary.
To fix broken equipment, unplanned downtime is excruciating,
especially when your factory is running closer and closer
to full capacity.
In a research project at the Vienna University of Technology, the KISSsoft design software was used to check a new drivetrain concept and the micro-geometry of the bevel gear stage for a UAV (unmanned aerial vehicle).
