Gearboxes are important assemblies within mechatronic systems. During the design phase of such systems it is essential to know the gearbox behavior under consideration of dynamic interactions with its environment. Holistic system simulation helps the engineer to understand this and to improve, adjust, or optimize gearboxes and their application.
Modern drivetrains with voltage-source inverters not only offer advantages like, for example, variable speed operation, increased efficiency and higher dynamics, but also an increase in failures caused by induced parasitic currents.
After decades of iteration, you might think manufacturing software suites are running out of new modules to add, but improving hardware is opening up new avenues for them to explore.
Many refineries and chemical plants are built with large pieces of rotating equipment in an outdoor setting exposed to the elements. The author has been researching thermal growth issues for decades across North America.
Couplings. There certainly is no shortage of couplings - or things to couple them with. There also seems to be no lack of applications for them. You say you need to reduce the transmission of shock loads from one shaft to another? That's a classic application for shaft couplings; but really, couplings are application-intensive. They're everywhere.
