It was recently announced that the planet Mars has at least one thing in common with planet Earth: all good things come to an end. In this case, the good thing is the recently announced and documented (Feb. 12) demise of the Mars rover Opportunity.
Cylindrical gear design can be divided into three steps. In the first step, rough gear pair dimensions such as center distance and face width are being estimated. Center distance and face width are directly linked to the available space (housing dimensions) and influence the overall size, weight and cost of the gears.
